Home > In Car Electronics (L322) > Calling all caravan and powered trailer experts |
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 |
I just bought a camping/expedition type trailer with its own in built leisure battery for lights, webasto, water pump etc. The battery has a lead connected for charging but just for attachment to a normal charger ie the leads just end up as bare wire terminals to attach crocodile clips to.
21st Jul 2013 11:31am |
No worries will do. There must be something in the air. Personally driving halfway down the country to spend a lot of money was better than dodging the masses obsessed with hitting a small ball with a stick that has taken over this part of the world! |
21st Jul 2013 12:02pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8625 |
http://www.westerntowing.co.uk/acatalog/Ca...agram.html
21st Jul 2013 12:22pm |
Ah the plot thickens a little! Mine has the white box as shown but the connector was disconnected. When connected the trailer lights work fine but when the trailer itself is disconnected the trailer warning light keeps coming on and off on dashboard even at rest (no jolting) and sometimes the indicator goes double speed and sometimes not. Maybe a loose connection somewhere or dodgy relay?
21st Jul 2013 3:43pm |
Yes, basically.
21st Jul 2013 4:06pm |
cleughy Member Since: 08 Mar 2012 Location: West Kirby Posts: 361 |
You can always get a nice little £10 solar panel and keep a trickle on the battery all the time |
21st Jul 2013 4:27pm |
Regardless of the electric being genuine or not, on the supplementary socket (white cover) pin 4 is positive for battery charging and pin 3 is the earth for it. That has always been standard.
21st Jul 2013 8:49pm |
21st Jul 2013 9:26pm |
This is all brilliant info. I knew you guys would know! I will check for switched live. Cheers |
21st Jul 2013 10:29pm |
Simple1 Member Since: 01 Jun 2013 Location: Somerset Posts: 112 |
The control unit for the 13 pin or white 7 pin socket should only allow charge when the alternator is providing over 13 volts, ie when the car is running. It isolates trailer below that TDV8 Vogue SE 2009.
28th Jul 2013 6:55am |
