![]() | Home > Maintenance & Mods (L322) > Spare Wheel Lift - Fitting Pics |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Yeah, probably is the SC wheel diameter. It does fit but once you've dropped the wheel in you need to work the straps from under the wheel so the lift can fit down the side. Not too hard to do, only takes a 30-60 seconds and is a lot better than lifting a huge wheel out of the car. Especially if you puncture off-road and don't want to drop to access height for obvious reasons. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3870 ![]() ![]() ![]() |
I know this is an ancient thread (found it using the search Stan) but I got the straps/handle etc from a breakers for 20 quid but it came without the bolts anyone happen to know what size they are? Geoff |
I can't remember but they are very standard i,e M8 or such but did you get the prop that goes into the tailgate locks to hold it open ? 2008 MY Supercharged
^^^^No I didn't get the prop but I can get from Dan later. I have some M8's Ill give em a try^^^^^ Geoff |
M8 too small, I'l get some M10 from the bay Geoff |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Hi,
Ill send you a PM with my address - thanks very much. |
