Home > Maintenance & Mods (L322) > 60000 mile service
J90
France 2006 Range Rover Vogue Td6 Java Black
60000 mile service
I have 8K to go before a 60K service is due but as I have a major european road trip coming up I'm going to bring the 60K service forward.
I have used the search facility on the forum and google and have been unsuccessful in finding out what is included in it. I'm curious, can anyone tell me what the major/important things need and should be done? I'm not bothered about the minor things I can check or do myself; everything else the 60K service requires I intend to have done asap. After reading all the gearbox issues I'm getting a warranty as well.
Ta, Chris.
Post #199280 17th Jul 2013 7:12pm
can you update your car profile so we know what you have..
any good, http://british4x4outfitters.com/Assets/PDF...verJAG.pdf ... - .- -.
Post #199284 17th Jul 2013 7:14pm
J90
Will do - 2006 facelift TD6
Post #199290 17th Jul 2013 7:28pm
Oil
Oil Filter
Fuel Filter
Air Filter
Cabin Filter
Diff Oil Front/Rear
Transfer box oil
Brake Fluid
Coolant flush and refill to the coldest weather rating you will come across(go for -25 to be safe in this country and europe!)
Aux belt
Grease all door hinges and slides
Grease bonnet hinges and cables(deffo this incase of brake down!)
And a general check over.
Stick in some strong windscreen additive as well to flush the crud out!!
I think if your really keen you could check the timing chain tension and aux belt tension but they should be ok if inspected and passed. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #199297 17th Jul 2013 8:02pm
J90
Thanks Kingpleb, there's a couple of things on that list I could do myself for the experience on the run up to the service itself.
Ta.
Post #199299 17th Jul 2013 8:07pm
RichTDV8
United Kingdom 2015 Range Rover Vogue SE TDV6 Corris Grey
I would get the air con regassed as well. replaces the lubricating oil and makes it nice and chilly for the tour Very Happy 3.0 VSE - 2015MY
Corris with Black, RSE, 22 turbines, privacy, deployables
Post #199320 17th Jul 2013 9:22pm
