![]() | Home > Maintenance & Mods (L322) > Help on how to check if radiator leaking |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35522 ![]() ![]() |
i would have thought the simplest way would be to get it up to temperature and maybe do a visual inspection and then maybe a piece of tissue paper to see if there are any fine sprays and obviously taking care not to touch any moving parts. ... - .- -.
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Think you can get leak detector kits, a fluorescent dye you can add to the coolant then run the system and shine a special torch to see where the leak it |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
take the fan off (left handed thread) undo the 4 little rivit things and remove the undertray 12? 10mm bolts then remove the fan cowel. use a torch and mirror to look for staining. should be red/orange or green/blue colour. you could try a pressure test but woukd req plugging the holes in the rad and a way of pressuring the system. or start the car without the above buts and look for a leak when warm. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
vogue12345 Member Since: 25 Jun 2013 Location: UK Posts: 18 ![]() |
Appreciate the advice guys - will try and look at it!
NormanP Member Since: 15 Mar 2013 Location: Oxford Posts: 136 ![]() ![]() ![]() |
I would suspect that includes a new rad - or it should, since when mine was done (about the same time) the job was £580, of which the new rad was £290. Norman Current LR: L405 Vogue TDV6 (MY 2014) Aintree Green/ Ivory interior Past LR: L322 Vogue 4.4 V8 (2002); Discovery series1 V8 (1995) |
You can get a pressure kit that you fit to the expansion bottle which you can then use a footpump or car pump on and get a little pressure in the system and listen for leaks with the engine off but nice and hot to make the thermostat stay open |
