Home > Maintenance & Mods (L322) > What to do? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
have you had problems with it? if not ,leave it alone... ... - .- -.
15th Jul 2013 5:59pm |
Dave ray Member Since: 19 Sep 2011 Location: Wirral Posts: 92 |
Thanks for the fast Reply will do that then battery is ok I think other than my radio screen has gone blank but it still works ? |
15th Jul 2013 6:02pm |
Pull FUSE 49 front fusebox in cubby and get out ans lock the car. Wait 5 minutes unlock fit the fuse and start the car. May work normally does. |
15th Jul 2013 6:03pm |
just make sure there's no gadgets left plugged in and with this nice warm weather it should be ok....might also be worth asking where you park it if they have a jump start facility, just in case.. ... - .- -.
15th Jul 2013 6:04pm |
Thanks for the responses |
15th Jul 2013 6:07pm |
Just pulled fuse 49 and screen is back on thanks |
15th Jul 2013 6:16pm |
15th Jul 2013 6:18pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
Maybe get a solar charger? |
15th Jul 2013 6:41pm |
While where at it drivers side rear entertainment screen not working is there a fuse for that ? |
15th Jul 2013 6:42pm |
Probably but not sure which.... |
15th Jul 2013 6:50pm |
Gruute Member Since: 05 Jul 2012 Location: Flanders Posts: 136 |
Put a charger on it. Ctek MXS 5.0. Works perfect.
16th Jul 2013 10:40am |
I am leaving for 4 weeks and have done so before and it always started first try. So I wouldn't worry about it too much unless you have been having battery problems. If you have it in a garage it is easy to put it on trickle charge then I suggest to do so, just to keep the battery topped up. It may be freezing again when you come back MY 2010 5.0 SC Galway green and sand interior!!
16th Jul 2013 1:09pm |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2289 |
My DB7 had this battery problem, after 2 weeks...dead. Bought a solar charger put it in the cigar lighter and problem gone.
16th Jul 2013 2:10pm |
