Home > Maintenance & Mods (L322) > Discs Drilled / slotted ?
Gollycrush
England 2006 Range Rover Vogue 4.4 V8 Cairns Blue
Anyone fitted Drilled and Slotted Front Discs 360mm dia as these listed? ( To Brembo Calipers )
http://www.ebay.co.uk/itm/RANGE-ROVER-L322...5876257%26
They're obviously aftermarket items, dont Land Rover make a similar item as all ive seen are solid / vented?
Post #198790 14th Jul 2013 12:17pm
hoppy
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
ive got drilled/slotted vented...but not brembo calipers free use of "RSW" all comms to anyone nearby
Post #198791 14th Jul 2013 12:35pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Those are not Brembo branded discs though, they are aftermarket ones that happen to be the same size as Brembo ones. I'd be worried they might crack or shatter. They will definitely squeal like pigs and probably wobble quite a bit under decent braking.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #198937 15th Jul 2013 4:28pm
Gollycrush
^ Many thanks Bow down Ive ordered original Land Rover Discs and Pads from Dan at Duckworths. Thumbs Up
Post #198941 15th Jul 2013 4:51pm
TheAllSeeingPie
No worries. Unless you go for high quality aftermarket stuff like AP, Brembo or Alcon I'd steer clear of anything else brake wise. EBC pads and rotors can be good, but I'd probably doubt they've tested them on FFRR's anywhere near as much as their core "tuner" market.
Post #198956 15th Jul 2013 6:04pm
Gollycrush
Genuine items supplied by Dan fitted now, no squeaks or rattles and all operational. ( On a whim i fancied the look of the drilled and slotted but after the advice decided to go Original ) Many thanks Thumbs Up
Post #200626 24th Jul 2013 7:29pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Don't think the drilled / slotted discs would handle high mileage........best sticking with OEM Rolling with laughter Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #200673 24th Jul 2013 9:44pm
Never ever ever ever do drilled!
You will regret the noise and the eventual warping and cracking with them Wink
Stick with slots/grooved from a good supplier like pagid or the like and you'll not regret it. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #200680 24th Jul 2013 10:25pm
