Home > Maintenance & Mods (L322) > Air suspension pipe leaking |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Just cut the pipe and put an inline connector in..... Photo to follow.
11th Jul 2013 11:15am |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 |
Thanks for that!
11th Jul 2013 11:29am |
Yip... If you google air compressors, compressed air etc in your area you will find a company that will sell them over the counter. They are relatively common. I used www.compressedaironline.co.uk as they had a local branch.
11th Jul 2013 12:20pm |
The pipe has worn through in just one spot, so I'm juggling between putting a complete replacement pipe in or just a short section to replace the affected pipe (with two inline connectors). |
11th Jul 2013 12:33pm |
The complete replacement part is LR018434 "pipe - air inlet"nwhich comprises all 3 air hoses from the compressor.
13th Jul 2013 8:39am |
Replacing the complete line looks a bit of a faf compared to the inline connector route, but if you are not sure the connector can handle the pressure then for peace of mind it's the way to go. My problem was an original fitting from landrover failed, so the fact that they use inline fittings must mean they are available.
13th Jul 2013 9:15am |
The part from Dan is the three preformed air lines with the rubber grommet attached which fits into the wheel well. I'm hoping that the leaking hose is the shortest one - but I was in the car up on the ramp keeping the compressor going so that they could find the leak and so did not see which one it was! |
13th Jul 2013 6:18pm |
