Home > Technical (L322) > decode vin
tcmnorcal
Ireland 2006 Range Rover Vogue TDV8 Tonga Green
decode vin
Hi
Can anyone help decode this VIN as it doesn't make sense
SALLMAM237A245436
Thanks
Conor
Post #198489 11th Jul 2013 8:05pm
Position 1
The very first letter or number of the VIN tells you in what region of the world your vehicle was made. Match the letter or number below to the first number or letter of your VIN to find out in what region of the world your VIN was made.
A, B, C, D, E, F, G, and H are made in Africa
J, K, L, M, N, P, and R are made Asia
S, T, U, V, W, X, Y, and Z are made in Europe
1, 2, 3, 4, 5 are made in North America
6 and 7 are made in Oceania
8 and 9 are made in South America
Position 2
The second letter or number, in combination with the first letter or number in the VIN, tells you in what country the car was made. You may be surprised to know that not all Japanese cars are made in Japan and not all GM cars are made in America and so on. Anyway, cars are made in over 80 countries and there are over 600 VIN country codes.
Position 3
The third number or letter is used by the vehicle manfacturer to identify what kind of vehicle it is. It could be a car, truck, bus and so on. Each vehicle maker uses different codes for this so go to the Automobile Manufacturer website for your vehicle to find out what the third position in the VIN means for your particular vehicle.
Vehicle Descriptor Section (VDS)
Letters and numbers in positions 4 through 9 is the Vehicle Descriptor Section. This information gives detailed information about the vehicle itself.
Positions 4 5 6 7 8
Here you can find out the vehicle model, engine type, body style and things like that. Each vehicle maker uses different codes for this so go to the Automobile Manufacturer for your vehicle to get the codes.
Position 9
This is the VIN Check Digit where you can use math to figure out if it is a correct VIN. It does not tell you anything about the vehicle itself.
Vehicle Identifier Section (VIS)
Letters and numbers 10 through 17 is the Vehicle Descriptor Section. This gives you information such as when it was produced, what options it comes with and so on.
Position 10
The 10th letter or number of the VIN tells you the model year of the vehicle. Note that this may be different from when it was manufactured, as many automobile manufacturers start to produce next years model this year. Find the model year by matching the 10th digit of your VIN to the table below:
A = 1980
B = 1981
C = 1982
D = 1983
E = 1984
F = 1985
G = 1986
H = 1987
J = 1988
K = 1989
L = 1990
M = 1991
N = 1992
P = 1993
R = 1994
S = 1995
T = 1996
V = 1997
W = 1998
X = 1999
Y = 2000
1 = 2001
2 = 2002
3 = 2003
4 = 2004
5 = 2005
6 = 2006
7 = 2007
8 = 2008
9 = 2009
A = 2010
B = 2011
C = 2012
D = 2013
E = 2014
F = 2015
G = 2016
H = 2017
J = 2018
K = 2019
L = 2020
M = 2021
N = 2022
P = 2023
R = 2024
S = 2025
T = 2026
V = 2027
W = 2028
X = 2029
Y = 2030
1 = 2031
2 = 2032
3 = 2033
4 = 2034
5 = 2035
6 = 2036
7 = 2037
8 = 2038
9 = 2039
As you can see, each letter or number has been assigned to two different years. To find out which one applies to your VIN, you must look at the 7th letter or number in your VIN. If the 7th VIN position is a letter, then your vehicle is made in 2010 through 2039. If the 7th VIN is a number, then your vehicle is made prior to 2010.
Positions 11 12 13 14 15 16 17
This is where the auto manufacturers enter unique information about the particular vehicle the VIN belongs to. The name of the assembly plant, extra options added to the vehicle, Production Sequence Number and things of that nature. This is different from company to company, so to find more details about this go to the Automobile Manufacturer website for your vehicle.
So in a nutshell you have a 2007 Mdl
Post #198492 11th Jul 2013 8:32pm
tcmnorcal
Thanks Joker
Something is just not right with this one, the VIN indicates a 4.0 V8 Petrol but it's actually a 3.6 V8 diesel, also registration on the car is mid 2006 but VIN is 2007
Post #198524 12th Jul 2013 8:18am
Registration date/year and model year are two separate things.
Post #198532 12th Jul 2013 8:42am
duckworthparts
Site Sponsor
my system says that VIN was built 2006 and is a TDV8
PM me your email and i'll send you a build sheet You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #198546 12th Jul 2013 9:48am
tcmnorcal
Will PM my email just need the three posts Thumbs Up
Conor
Post #198568 12th Jul 2013 1:19pm
duckworthparts
Site Sponsor
sent Thumbs Up You can paypal direct using - www.paypal.me/duckworthparts
Post #198570 12th Jul 2013 1:31pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Hi Joker, think the VIN info is wrong way around for 7th character. You say if 7th character is a number it is pre 2010 and if a letter, then car is 2010 onwards, but mine is a 2006 car and 7th character is the letter 'M' . Just spotted it as I wanted to see what my VIN meant and saw your thread. Smile Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #205551 25th Aug 2013 12:50am
