![]() | Home > Maintenance & Mods (L322) > Using a Trolley Jack |
hi, just done my ones,plus disc and hand brake shoes... i found the best place was at the end of the sus arm near the shock mount, the arm is at its widest, once up get a axel stand under it to be safe, remember you will need to release the hand brake if changing the disc, i would have a spare pad sensor just encase. found them very easy to do, don't forget your copperslip ..
I always use a very thick plank of wood on the jack to spread the load when working on the back. Mine has teeth though so I dont want it to dent the arms.
hi, yes good point, my jack has the hard rubber pad. just to add i was told not to lift it under the diff, even know that it would look to be a good place, not sure if thars right. V8 facelift Range Rover Autobiography 22" wheels.
+1 ![]() |
McSwerve Member Since: 20 Jan 2010 Location: Bedfordshire Posts: 25 ![]() |
Thanks for the info and tips.
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 773 ![]() ![]() ![]() |
So how did you get on?........
there you go and dont you fill better for doing that...i know when i done my front and back i gave it a good clean under there and when finished i know it was done properly.. V8 facelift Range Rover Autobiography 22" wheels.
Sorry for the delay, just had a great week away.
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
Does everyone just use a 2 tonne trolley jack? 2006 Mercedes CLS
hi, my one is a 3 ton but if you are only lifting one corner i would think thats ok, could only be a ton at the most on the front corners but i would invest in a pair of good axel stands,better safe then sorry..saying that and looking at the pics,dan uses a 2 ton jack. V8 facelift Range Rover Autobiography 22" wheels.
I bought a 3 tonne one just to be sure, plus it's handy if I ever need to use it on my van, was just curious really. 2006 Mercedes CLS
