Home > In Car Electronics (L322) > 2006 RR HSE Camera Upgrade with a 2010 Camera |
Follow these instructions ….
8th Jul 2013 8:30pm |
kadas Member Since: 23 Oct 2012 Location: California Posts: 19 |
This where he modified the stock camera housing to make it fit
8th Jul 2013 8:56pm |
Good job mate, picture looks quite good. MY 2010 5.0 SC Galway green and sand interior!!
9th Jul 2013 7:21am |
muddycharles Member Since: 05 May 2011 Location: Miami, FL Posts: 89 |
Dear Kadas,
18th Jul 2013 2:11pm |
No the camera housing stays in the same place.
18th Jul 2013 5:06pm |
You have a 2008 I just noticed so I am not sure if it is like my 2006. Any decent radio installer will be able to handle the job if you give them the 2 parts. |
18th Jul 2013 5:07pm |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 |
worth just getting the 2010> camera housing for £6.00 You can paypal direct using - www.paypal.me/duckworthparts
19th Jul 2013 7:41am |
if I knew that I would have totally went that route. That would have saved so much time. Good call!! |
19th Jul 2013 6:42pm |
Hi Dan,
20th Jul 2013 12:56am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Alex, if you want to but a 2010 mount from dan then you ideally would need to drill a new hole approx 80mm further along to mount the later camera in the same spot it is mounted on the late model cars...
20th Jul 2013 9:50am |
that probably is not a good idea (drilling a new hole) that is why the installer had to break apart the plastic sleeve that plugs from the new wire into the 2010 camera so that it would clear the internals. I will post pics of the stock end of the 2006 camera and wire that is one piece (camera and wire together) and the conversion I did is 2 parts put together and shaved down to make it fit.
20th Jul 2013 6:50pm |
Im wondering how much shaving needs to happen to the connector.
22nd Jul 2013 10:22pm |
The entire white housing needs to be removed. The pictures you see are with the stock 2006 housing in the factory location, nothing was moved. the housing of the 2010 camera needed to be shaved down to fit in the stock 2006 camera mount on the rear of the vehicle.
23rd Jul 2013 1:29am |
Much appreciated on my side. 2008 HSE B. Grey
23rd Jul 2013 1:09pm |
