Home > Technical (L322) > Key remote functions
Duke Thrust
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Chaps, is it only a LL main stealer that can change the function of the keys?
When the unlock button is held the windows open, I'd like to change this to the memory seat function.
Post #19770 10th Jun 2010 9:26am
jayzee
2006 Range Rover Vogue SE Supercharged Java Black
If you have the window/sunroof open/close feature activated already, you should be able to do the seat memory too, as I believe it is a standard working option on all Vogues.
For some strange reason, I did not have the window/sunroof feature (memory seat was fine though), but had this activated at the last service.
Do you have the car's manual to hand? It explains fully in there.
You set the seat memory for each key with the key in the ignition. Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD!
Post #19777 10th Jun 2010 9:54am
