Home > General > Flat Battery...AGAIN!
Vogue
just thought - to double check you could swap the front wheels to the rear to see if this makes a difference
Post #1961 22nd Dec 2008 10:37am
that would only prove balance problems though yes? Discovery 4 HSE
Post #1963 22nd Dec 2008 1:31pm
Vogue
If it still wobbles then its the discs. If it doesn't wobble anymore then its the wheels - either way you should know one way or the other - Worked with one of my vehicles. My guess though is that if it only occurs when you touch the brakes its got to be a disc, otherwise the vibration would be there all the time.
Just a quick thought, If you have towed something very very heavy and used the brakes excessively this can warp a brake disc - usually on the front. I also know someone who had very rusty discs and drove a car for a couple of miles with the brakes lightly on to try to clesan up the discs - result was a badly warped disc...
Post #1977 22nd Dec 2008 10:58pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
RRUK Shame you arn't down my way
Whistle
Post #1986 23rd Dec 2008 7:29am
indeed! Discovery 4 HSE
Post #1991 23rd Dec 2008 10:10am
