Home > Maintenance & Mods (L322) > Steering Tilt adjustment: Problem fixed |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 |
I had a problem which was intermittent and then got worse whereby the steering wheel wouldn't lift up when you removed the ignition key, and wouldn't come back down to memory setting once the key was replaced again.
2nd Jul 2013 1:50pm |
And here's a link to how to remove the cowling around the steering column
2nd Jul 2013 1:51pm |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
Mine kept sticking at the top of the vertical movement and the only way to release it was to remove the cowl and put a spanner on the nut at the end of the vertical screw thread.
2nd Jul 2013 2:42pm |
