Home > In Car Electronics (L322) > SATNAV Won't boot up
NKSC
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
I'm having a problem with my SATNAV not booting up. It displays the Land Rover logo but goes no further than this and the orange light on the power button is also flashing.
I have pulled the fuses that i think are relevant and also disconnected the battery but it is still doing the same thing.
Any ideas would be appreciated. Thanks.
Post #197206 2nd Jul 2013 10:34am
low voltage on the battery ? ... - .- -.
Post #197210 2nd Jul 2013 10:59am
This happens with water damage to the Nokia module in the boot. Check the connector does not have corrosion on the pins. Thumbs Up Previously..
Post #197213 2nd Jul 2013 11:19am
NKSC
Thanks guys.
I finally found the answer in your post Contraband - http://www.fullfatrr.com/forum/topic9192.h...+bluetooth
I have bypassed the bluetooth module by aligning the fibre optic cables in a small piece of airline tubing. Everything else is now functioning OK but obviously the bluetooth module is faulty as I found some corrosion on the pins. Time to find a replacement module.
Cheers Thumbs Up
Post #197219 2nd Jul 2013 11:53am
WIGGS....
Post #197221 2nd Jul 2013 12:09pm
Wiggs needs a working Nokia as a replacement, that's a problem when yours is damaged !
Glad you got it figured out tho' NKSC. Its a great feeling when it bursts back into life.. Thumbs Up Previously..
Post #197223 2nd Jul 2013 12:14pm
