Home > Technical (L322) > Parking sensors inop!
winslo
2005 Range Rover Vogue Td6 Adriatic Blue
So my parking sensors are not working, get the long beep and flashing light.
Walked around the car listening for the clicks and one off on the front and one off on the back
So my next question, where is the best place to get 2 new sensors from?
Also got the usual rear wiper issue, need a motor! Agasin best place to get one? I did an enquiry on partsgateway and price are crazy!
Cheers all
Richard
Post #197199 2nd Jul 2013 9:37am
Check the looms while the bumpers are off for £18 each they are worth replacing as fail more often than the sensors. Two minute job each end with the bumpers off. Thumbs Up
Post #197200 2nd Jul 2013 9:50am
try moving a good sensor to a suspected faulty one to see if its the sensor or the wiring..
sensors and motor from ducky dan .. ... - .- -.
Post #197201 2nd Jul 2013 10:06am
Dolphinboy
Hi Winslow, I have a spare brand new, still in packet, sensor (black) which u can have for £20. Gaz's advice ref new loom is good but check you haven't got a tear or kink in the outer sensor wires as this is where they normally tear due to their thing core. Bit of leccy tape did the trick for mine (hence the unused sensor)
Ref the rear wiper motor, look at RRUKs excellent post on how to take off, clean and get it working again. I have done this to both my RRs and not had a problem with them since. It's normally just a build up of cr@p inside due to the poor design. Should take less than an hour to do.
Post #197202 2nd Jul 2013 10:07am
winslo
It is in the garage later today for a thermostat so will be chekcing tyhe other things too
I can only find RRUK post on how to replace and new motor and not fix and existing one, is there a link?
The sensor on the rear thats failed id the n/s end sensor and the front is the OS middle one next to plate
Thanks
Post #197203 2nd Jul 2013 10:25am
Dolphinboy
thread detailing the stripdown to clean it all out or replace the non return valve, which tends to get blocked.........
http://www.fullfatrr.com/forum/topic884.html?highlight=rear+wash
http://www.fullfatrr.com/forum/topic8700.html?highlight=rear+wash
http://www.fullfatrr.com/forum/topic6402.html?highlight=rear+wash
http://www.fullfatrr.com/forum/topic4298.html?highlight=rear+wash
http://www.fullfatrr.com/forum/topic2067.html?highlight=rear+wash
Post #197208 2nd Jul 2013 10:45am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Anyone know the part numbers for the rear and front PDC looms? Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #197259 2nd Jul 2013 2:48pm
give Ducky Dan a shout re loom prices.. ... - .- -.
Post #197266 2nd Jul 2013 3:11pm
As above the rear is £18 from Dan and £20 at most other LR Parts (local)
The front will be similar money. Thumbs Up
REAR PART NO: LYMD001992 (Number on invoice but looks odd)
Post #197269 2nd Jul 2013 3:46pm
Flashman
Nice one Gaz! Tom
Current Drive
Previous Drives
Post #197275 2nd Jul 2013 4:28pm
