Home > Maintenance & Mods (L322) > 03 RR, no side lights, no warning message
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
had one side light out on my 03 RR for a week or 2 (i know, i know), ordered 2 replacements from ebay as recommended on here (the canbus free LED ones), went out to fit them and didnt have either side on when I started her to see what one wasnt working, car was running, switch was on its first setting 'sides' but neither were on, but i didnt get the usual 'ping' sound when i started her, and no error message?
Could this be the swtich faulty, or possibly both bulbs gone? Not had a chance to swap the bulbs yet as I'm working away this week, so just doin a bit of research til im home
Post #197166 2nd Jul 2013 2:37am
B9er
Northern Ireland 2010 Range Rover Autobiography 5.0 SC V8 Java Black
Re: 03 RR, no side lights, no warning message
LED bulbs are diodes which can only pass current in one direction i.e. they are polarity sensitive. I would suggest your first task is to remove the bulb from its holder and place it back having turned it 180 degrees. If you look closely at the bulb. It's terminals should be marked + & -. Hope this helps. Should've been old enough to know better...doh!
Current 2010 5.0 SC Autobiography
Previous 2006 TD6 Vogue SE
Previous 1998 P38 4.6 Vogue Autobiography 50 (No 10)
Post #197167 2nd Jul 2013 5:03am
+1 for the above Thumbs Up
Post #197182 2nd Jul 2013 8:00am
mrblonde
sorry guys, I didn't explain. its still currently got the old bulbs in, the originals (whatever they are)
new LEDS to fit, but not yet
Post #197283 2nd Jul 2013 4:57pm
has been said that if one bulb goes the other is sure to follow, happens with xenons apparently...
if the rear sides are working then i would suspect both fronts have failed and the only way to find out is to replace.. ... - .- -.
Post #197285 2nd Jul 2013 5:01pm
