Home > Maintenance & Mods (L322) > Steering Wheel Tilt Motor replacement
This should help someone when dismantling the interior to get at the steering wheel tilt motor.
To get to the motor do the following to aid access:
1. Put drivers seat all the way back
2. Extend the steering wheel all the way out.
You will need a size 24 and size 25 star bit.
The lower steering wheel cowl trim has 3 fasteners. The front and rear fasteners are the same size, 25 star bit, and these secure the trim to the steering column. The centre fastener is a size 24 star bit and holds the upper and lower cowl sections together.
I put them in a piece of cardboard to illustrate for you:
Here's a picture of the lower cowl trim when removed.
Once you have removed these, there are some clips holding the upp and lower trim together, and some holding those trims to the flexible gaiter neck.
Here you can see the clips in question, simple 'ball and socket' affair, nothing too hard to pull apart.
Now you have access to the motors. This photo looks at the underside of the steerinng column from the footwell. You can see the tilt motor on the left (The one with the tape on it), and the reach motor in the middle of the column. You can see the screw spindle that is situated horzontally in the photo, this is what winds the wheel up and down.
To remove the tilt motor, first remove the electrical connector on the top and then there are simply 2 allen head screws holding the base of the motor in place. The tilt screw spindle locates into the right hand side of the motor. Discovery 4 HSE
Post #196993 30th Jun 2013 1:39pm
rathbranV8
Ireland 2002 Range Rover SE 4.4 V8 Oslo Blue
thanks RRUK Thumbs Up
Post #197163 1st Jul 2013 11:13pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
I need to replace the in/out screw as per meerbush, where is that on the photo?
Post #197214 2nd Jul 2013 11:24am
The in/out screw (reach motor) is not shown in my pictures but you can see if when all of the above is removed, however it is harder to get at. Discovery 4 HSE
Post #197247 2nd Jul 2013 1:43pm
rathbranV8
Hy RRUK,
I'm taking the cowl off the steering later but cannot find a T24 size torx head anywhere as you listed for the cowl fastener.By any chance was it a typo and it was a T20 size
Where did you pick up that size tool for the job...?,need to get some longer reach Torx bits later
rgds
Post #204073 15th Aug 2013 8:49am
Martin
Site Admin
There's no such size as a T24 [1] so assume it's a mistake. But if you have a set of Torx bits (always handy) then just find the size which fits Smile
1: http://en.wikipedia.org/wiki/Torx#Sizing
Post #204074 15th Aug 2013 9:03am
rathbranV8
Thanks Martin,have a set but they wont reach as the cowl gets in the way.Need to get some longer reach ones for the job,will report back later
Post #204075 15th Aug 2013 9:07am
Sea Aitch
England 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Coincidentally, I was puzzling over the T24 reference for the screw that holds the two parts of the cowl together, but I tried a T20 on a long 1/4" drive socket extension, and it was the correct size. I searched everywhere I could think of to buy a T20 screwdriver with about 6" of reach, before I gave up, and then I found all the components I needed in my Halfords Socket set Embarassed
The original write up by RRUK was otherwise excellent by the way. Thumbs Up
Post #204203 15th Aug 2013 7:04pm
rathbranV8
Got the shroud off.Used 2 Teng torx screwdrivers and the sizes are T20 x 1 and T25 x 2.
I agree with above,great write up and pics and much appreciated Thumbs Up
Post #204244 15th Aug 2013 10:05pm
