Home > Technical (L322) > td6 turns over longer than it should before starting. |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
Had the same issue and it was an injector. Fortunately it was the first one and easy to change It started like your symptom an gradually got so bad I thought the battery would go flat Took me about 30 minutes to fit the new one and I now add Miller injector cleaner to my tank to try and ensure it doesn't happen again. |
27th Jun 2013 5:59pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
^ had the same issue, and the same resolution. The dodgy injector drains all the pressure off the fuel rail so it won't start. When it is running there's enough pressure for the other cylinders to run ok.
27th Jun 2013 6:42pm |
b20wht Member Since: 08 Apr 2013 Location: lincs Posts: 45 |
ooo great, how did you find out which injector it was? is there a test that can be done while they are still fitted? and dare I ask how much are they?
27th Jun 2013 6:54pm |
Leak off test. I didn't do it, it failed before I got round to it and then the garage fixed it. I hear it's quite easy to do. |
27th Jun 2013 6:58pm |
ok thanks. If it was an injector, would it turn over for longer the longer you leave it between starts? (ie more fuel leaked the longer its left) As mine seems to take 3-4 seconds every time no matter how long its left (other than the 2 times mentioned above) |
27th Jun 2013 7:03pm |
dunno. Mine was variable. |
27th Jun 2013 7:16pm |
It could also be the glowplugs if its taking longer to start the longer you are leaving it. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
27th Jun 2013 7:31pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2655 |
Get it plugged in I had the same symptoms, injectors were the cause. |
27th Jun 2013 7:46pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8626 |
Could be the glow plugs, but im thinking injector like the others. I had exactly the same in my e39 530d (same engine) was one faulty injector. Just turned over for ages then fired. Is the glow plug light going out quickly? This will usually take longer to go out if the glow plugs are faulty.
27th Jun 2013 8:33pm |
Glow plug light only stays on for about a second or so. I don't think its glow plugs tbh, sounding more and more like an injector from all the comments. I will get it plugged in and hope it shows something. |
27th Jun 2013 9:24pm |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 |
leak off test is better for detecting overflowing injectors
27th Jun 2013 9:34pm |
