![]() | Home > Maintenance & Mods (L322) > TDV8 4.4 oil filter |
oldcro Member Since: 17 Mar 2012 Location: Shetland Posts: 359 ![]() ![]() ![]() |
Where is the engine oil filter on a 2012 TDV8 4.4 litre and how do I get to it?
Badly replaced Oil Filter can also result in low oil pressure and catastrophic failure.... |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 ![]() ![]() |
Exactly, fortunately mine was just a slight leak. |
Thanks Vogue, I'll look out for the seal and make sure the filter is fitted upside down. Will check the old filter and replace the same way. |
Apparently it is a very regular occurrence. I would call it a design fault if even a pleb of a tech cannot complete such a simple task.
Gazellio, your post is doing wonders to my confidence, fortunately a mechanic (Not Landrover trained) will be on hand to stop any obvious mistakes. |
Not LR trained is probably a bonus! Judging by some if the experiences we have had |
