![]() | Home > Maintenance & Mods (L322) > 4.2 Supercharged Idling Rough |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Mine burbles nicely on tickover and I worry not one bit.
It does Si, most days, only about 10 miles covered.
It sounds like you may have a fuel issue, i.e. dirty fuel or water in the fuel. Mine is super smooth (granted I had the entire fuel delivery system changed thanks to a cheap fuel pump on Ebay) following a complete clean of the fuel tank, fuel system and inlet tract.
Hi, the fuel tank was on 1/4 this morning when the symptoms were present.
If it is the famous 1/4 tank issue, then the dealer will have to sort it out. And the fuel pump at "normal" price is quite "stiff", in the 300+ range !!. Mine was 50 thanks to Will spotting it on Ebay |
What's the 1/4 tank issue? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35465 ![]() ![]() |
this might help explain,
Some dealers do still have some in stock but few and far between at such prices |
Seems to only really effect Supercharged models...
Possibly due to the higher fuel flow required but the TD6's have had the odd one fail as well in this way as its the balancing part that burgers up!
That's really helpful thanks...
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Sometimes when you start it the viscous fan can be partly engaged and give the effect of the engine racing, mine does this quite often, it's nothing to worry about - my guess is this is what you / your wife has noticed. Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
The viscous coupling may be getting on a bit if its doing that i would think. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
