Home > Technical (L322) > Inspection warning
onyx
England 2005 Range Rover Vogue Td6 Java Black
Inspection warning
Hi, had car serviced today cus kept coming up Inspection 06 2013, but garage cannot reset it.it just keeps returning to the inspection message ?,any ideas ?
Post #194947 18th Jun 2013 4:58pm
They should not have done the job if they could not remove the service warning. It says to me that they have never done a FFRR before! Unless I have it wrong and you have a fault? Will probably need a dealer to switch off the message and I would be asking your garage to pay the bill!
I take it you have the newer touchscreen facelift model? Older ones there is a hack to clear the message, but it does not work on 2005 facelift onwards... Previously..
Post #194949 18th Jun 2013 5:10pm
onyx
They had it all connected up to his auto reader and it told him to reset it manually using dashboard reset button and a certain sequence.he has done them before.
Post #194950 18th Jun 2013 5:16pm
