![]() | Home > Maintenance & Mods (L322) > Suspension Question |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35610 ![]() ![]() |
could be an intermittent fault in the abs sensor. ... - .- -.
When my front wheel struts and bearings were replaced, the height sensors went out of range and that caused it to act up. Also the damaged one of the ABS leads setting of the HDC inactive, ABS and DSC inactive.
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
No recent work. It had a new windshield last summer, but I'm not aware of any low down/underneath type work. I need to get the car in for a routine service and oil change.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
It will more than likely be your battery voltage at the point of start up... If the battery is under charged during a start up, it will first flag up a suspension issue as that's the first "weakest link point" Now, im not saying your battery is faulty! But, for example...one day if you park your car at an event and keep returning to it hourly for the day and unlocking the car and opening doors before locking and leaving then returning an hour later, and so on. I bet you will get the message when you start up at the end of the day. Due to the battery drain from the ECU's waking up, interior lights and central locking going... So usually, your symptoms can be put down to battery voltage at point of start up... Up to you to look at your batteries age now ![]() |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
sometimes at the car wash (and only there) i got this - just restart the engine and it is gone ..... |
Thanks all! I don't know the age if the battery and alternator, but I had them tested at the last service after hearing almost all FFRR problems could be traced there. The battery and charging system both passed as OK and no remediation was recommended.
well i got exactly that problem !! Since they changed my brake discs and pads and front wheel bearings i got this errors coming up ! What is the f***** ![]() ![]() ![]() ![]() 2024 RR Velar 2021 AM new Vantage |
new abs sensors... ... - .- -.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
I was getting the Suspension Fault message at start-up and sometimes during driving mine, it needed to have the air compressor re-work kit done by the dealer, wasn't much money and it fixed it. Discovery 4 HSE
well it started to occur after the repair i mentioned before and now when i brake hard on the highway it comes up or fast cornering at high speed...... All my spelling errorz are belong to me!
Hi Angel, my problem was cured by replacing the ABS sensors on the front wheels (that is where the work was done). The guys here are not very "careful" in their work. I have on many occasions moved the brake caliper such that the hoses weren't under tension bent around the socket crimp edge |
well i will get it checked at my local stealer laterz... |
On mine it threw up a fault, the HDC and ABS were out of commission so it was easy. Maybe yours is just dislodged or the connector is not fully seated so it loses contact a bit every now and then.
thanks mate |
