Home > Technical (L322) > Westfalia towbar query
Andy
On the detachable section, can the rubber bung/grommet thingy at the top be replaced?
Post #194420 15th Jun 2013 1:19pm
+44 1785 226888
Give westfalia a ring.
They may or may not be able to help. There is nothing that can't be fixed with a hammer😜😜
Post #194424 15th Jun 2013 1:29pm
Andy
I'll give them a call on Monday- thanks.
Is it a critical part or just a dust cover?
Post #194445 15th Jun 2013 3:27pm
Not sure but i think that they wouldnt make a loaded part out of plastic. As far as i can sus it the ball bearings are what holds the bar into the reciever...... There is nothing that can't be fixed with a hammer😜😜
Post #194492 15th Jun 2013 9:20pm
Andy
It's scrap apparently. Westfalia said they could repair it for £100 but said it wasn't worth doing
Post #194707 17th Jun 2013 1:07pm
Does it not just help with location or as a light damper? Cant see it having much affect! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #194712 17th Jun 2013 2:05pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Have a look on eBay for an obscure model one you can dismantle. I'm watching a couple that I can remove the lock off (mine is knackered). If I buy one and it has the spare you need you can have it. Watch this space....
Oh btw westfalia also fired me off. Get the impression they want to sell full units, not parts. My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #194734 17th Jun 2013 6:04pm
johnboyairey
if you pull and twist your knob, do your balls go in a bit and loosen? try pushing it into the hole and it should stay in. if so, its working fine....i have a bit of rubber on mine too. looking at the pic, i would lube those balls! Razz
Post #194794 17th Jun 2013 11:42pm
