Home > Camping, Caravanning and Holidays > thinking about caravaning - towing / tow bar requirements?
cleughy
England 2004 Range Rover Vogue Td6 Santorini Black
Go to www.bob.org.uk and join for free, get one nice discounts
Post #194290 14th Jun 2013 9:07pm
stagger
I had my towbar and electrics fitted by Horsforth towbars, no problems happy to recommend them.
Post #194301 14th Jun 2013 9:29pm
wedgel322
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
Thanks for all the good advice so far. Will look into things a little more over the week end. 2003 Range Rover HSE 3.0 TD6
Java Black, Cream Leather Heated seats all round, Sat Nav, Rear TV's.
2013 Range Rover Autobiography 4.4 SDV8
Black, black and piano black. Rear entertainment system. 22 inch turbines
Post #194308 14th Jun 2013 10:02pm
kingpleb wrote:
Tip for towing. Park up the unit and raise suspension to offroad height. Drop the dolly wheel to take the strain and then get back in the car and drop to normal ride height and drive her off and adjust the height as needed.(
You will of course need to unplug your towing electrics first though as they inhibit the air suspension when plugged in... Thumbs Up
Post #194320 14th Jun 2013 11:39pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
My air suspension still works with the electrics plugged in (OEM electrics) Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #194375 15th Jun 2013 10:18am
So does mine, but i think it only deactivates motorway mode....... Should you be doing 90 with a van on..... There is nothing that can't be fixed with a hammer😜😜
Post #194418 15th Jun 2013 1:14pm
I think it should deactive if its enabled fully on the CCF Smile The plug and play bits just tend to deactivate the rear PDC when plugged in Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #194442 15th Jun 2013 3:23pm
Mine was programmed into the ccf by our local indy with autologic, supposedly.
I will get the stealer to check it out when its in for its next service, when im back from Le Mans. There is nothing that can't be fixed with a hammer😜😜
Post #194533 16th Jun 2013 9:38am
