Home > Technical (L322) > auto gearbox usage
DTaylor
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Chawton White
auto gearbox usage
noob question, first auto I have ever drove, im one month in and wondered:
at long waits at lights do I change to neutral or stay in drive, can one or the other wear the box out faster?
im guessing its an rtm fault im having
stan I have searched, however I only find problem gearboxes Sad
Post #192800 8th Jun 2013 9:45pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Some help from the ROSPA website, which does say the following.
Quote:
When stationary in traffic, even for many minutes, it is not necessary to move the gear lever into neutral because the torque converter absorbs the engine’s propulsion force but does not transmit it all to the gearbox. No wear is taking place. In fact, more wear will take place if you engage neutral then engage a drive gear when it is possible to move off. Most gearboxes will automatically select first gear when the vehicle becomes stationary.
http://www.rospa.com/roadsafety/adviceandi...boxes.aspx
Post #192803 8th Jun 2013 9:51pm
DTaylor
that's exactly what I needed, thanks very much Thumbs Up
Post #192804 8th Jun 2013 9:54pm
Hmmm, I am pretty certain my TD6 ('02) stays in gear when stationary, whilst my Audi will drop out of gear ('04).
I prefer to go to Neutral when stationary as the TD6 starts to vibrate a bit, "telling me" something is straining somewhere.
Also, if you don't put your handbrake on, you are not really "stopped".
Many discussions on forum about this, lots stay in drive at traffic lights, some go to Neutral or Park. .
Post #192810 8th Jun 2013 10:29pm
DTaylor
I have been feeling the strain/vibrate, that's the reason I ask, don't want to kill the gearbox.
Post #192812 8th Jun 2013 10:32pm
pld118
I've always switched to park and applied handbrake when stopping in traffic.. for safety and thinking I was prolonging the gearbox..
Post #192830 9th Jun 2013 6:53am
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
SWMBO says that the drivers manual recommends selecting neutral or park if stationary for more than 30 seconds. I haven't read it myself and I don't bother though.
Post #192877 9th Jun 2013 11:23am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Handbrake on and drive for me, unless it's a long stop, thn I'll put it in park and watch BBC news
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #192879 9th Jun 2013 11:34am
TugRR
Neutral every time, either with hand or footbrake applied -
Furthermore, on long descents, pop the gearbox over to "sport" to knock it out of top gear - it'll save your brakes -
Thumbs Up Where do you go after one of these . . . ?
Post #192883 9th Jun 2013 11:55am
From Owners Manual ('02)
Page 123 Fuel Economy:
"When stationary in traffic, select neutral ('N') to improve fuel economy and air conditioning performance"
Page 134 Using Automatic Gearbox:
"DO NOT allow the vehicle to remain stationary for any length of time with a drive gear selected and the engine running
(always select 'N' if the engine is to idle for a prolonged period)"
Nuff said Thumbs Up .
Post #192887 9th Jun 2013 12:07pm
its a judgement call with me.. in fast moving junctions i leave it in drive but at roadworks or slow junctions its into park... ... - .- -.
Post #192889 9th Jun 2013 12:28pm
Richcl
I shift into neutral as my handbrake is sh**te!! Laughing
Post #192901 9th Jun 2013 2:44pm
mjdronfield
Neutral and footbrake if its a quick stop, or Neutral and handbrake.
I try and read the road a bit, so can sometimes roll up as the traffic moves and end up not having to actually come to a full stop. Can't do this all the time, obviously.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #192903 9th Jun 2013 3:04pm
I never use Park unless parking. Using Park mean going through Reverse which may flick on rev lights or worse. On TD6 Neutral is always a good bet. TDV8 & V8 are OK in gear for short stops but Neutral for longer stops. Thumbs Up
Post #192908 9th Jun 2013 3:37pm
robjp
Wales 2004 Range Rover Vogue Td6 Zambezi Silver
Neutral/Handbrake for me if I think I'm going to be stopped for more than 10 seconds. Otherwise I'll leave it in D with handbrake.
Post #192909 9th Jun 2013 3:40pm
