![]() | Home > Technical (L322) > Engine oil |
oldcro Member Since: 17 Mar 2012 Location: Shetland Posts: 359 ![]() ![]() ![]() |
I have a 2012 Westminster TDV8 4.4 litre and wondered if using Mobil Super 3000 X1 5w-40 oil would be alright.I'm concerned as this oil does not conform in any way to that mentioned in the handbook (C1 SAE 5W-30 WSS-M2C934-B). Would using the Mobil oil have any long term effects or void my warranty?
Mobil do a 5W-30
Contraband, I would never consider using any oil which does not conform in any way, which is why I posted this thread. I had the first service recently carried out by a large Land Rover dealership who did exactly that though and are now ignoring my requests to rectify their mistake.
robjp Member Since: 14 Jan 2013 Location: North Wales Posts: 104 ![]() ![]() ![]() |
If you can show, beyond reasonable doubt, that they have failed to use the correct engine oil, putting any warranty you may have at risk, or putting your property at risk of damage or early failure, then write to them enclosing a copy of your proof. Inform them that it is their responsibility to carry out their work diligently and competently, and that your documentation shows that they have been grossly negligent. Explain that distances, ferries, hotels, make it unreasonable and expensive for you to travel back for them to rectify their own screwup, and ask them to come up with a solution 'acceptable to yourself'. Send it to their MD/Dealer Principal by recorded post, so that they can't deny receipt.
Thanks robjp for such excellent advice, I think I'll start by phoning LR customer services and see what they say first. I really do not want to go to court so that will be a last resort.
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
wslr Member Since: 04 Dec 2011 Location: Wellington, Somerset Posts: 64 ![]() ![]() ![]() |
The Ford spec Castrol Edge 5w30 is the one the dealers would/should be using in this case as it has the 934 spec for the DPF vehicles.
A good description of why using the correct oil prolongs the life of your DPF. If you have had your engine oil changed by a dealer ask what oil they put in and if not the correct spec oil, request an oil and filter change to the correct oil be done asap at their expense. Any problems contact Landrover Customer Services and tell them.
