![]() | Home > General > Thinking of an Upgrade |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
I just did the same as you today. finally took the plunge and traded my TD6 with just under 120k for a TDV8 Vogue SE with rear entertainment. My TD6 was a touch screen model but was the non face lifted square headlamps model and I got to say its a revelation driving the TDV8 in comparison to the TD6. I initially thought the same as you ie; would the change be enough, but so far I am well happy with the move. As to spending more on a 2010 model that will be more a case of economics and preference for looks. Personally I prefer the less bulbous front bumper of the 2005/9 cars, and also prefer the look of the less busy tail lights, while I do like the safety side of the new rear lights ie; the indicators are much more visible especially when breaking everything else about them has no appeal to me, but this is just my perspective. And the headlamps are also visually a disappointment on the 2010 in my opinion. I can only think there must have been a shortage of LED's in Land Rover when the designed them as to put under a dozen LED's in each headlamp is neither here or there. It would have been much nicer to have done what they did with the L405 and Evoque where the LED's are much tighter together giving the impression of a solid line or circle. Again this is all just my feeling on the subject and everyone has varying tastes etc. I personally didn't have the budget to stretch to a 2010 model so went for the pre 2010 TDV8 with the higher SE spec.
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Just my two cents, but over here I think the 06-09 models offer the best compromise between performance/features and price. They've also had a lot of their depreciation already done. If $$ isn't a concern, a 10+ facelift is great! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8742 ![]() ![]() ![]() |
It depends on your budget really, personally i would go for a late 05-09 car, rather than a facelifted one, you will effectively be getting a massive improvement in performance over the td6, the best thing if you cant decide is to look at both, drive both and then decide for yourself which you prefer.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3888 ![]() ![]() ![]() |
