Home > Maintenance & Mods (L322) > Uh oh :( |
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 |
Just spent an age yesterday changing all four sets of brake pads, I noticed that my front O/S was an absolute pig to wind back in.
6th Jun 2013 9:08pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
I got a recon of ebay for £45. Look for BMW X5 calipers instead if range rover. At £45 its not worth the hassle. A seal kit is about £7 but you might need pistons and the ballache of doing the job.
6th Jun 2013 9:30pm |
Ah I see, typical Range Rover price tag attached to the same part I guess. TBH if i can get one for £45 I would happily swap it over rather then mess about stripping and cleaning/sanding and de rusting etc
6th Jun 2013 9:33pm |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
If you remove it from the disc and push the piston in & out a few times to see if it'll loosen up.
6th Jun 2013 11:49pm |
Bingo! You are not the shop looking to make a buck off the owner (replace!replace!), you are the owner! Work it in and out and get it going again. Works in the large majority of cases. Only look to replace if the rubber seal is torn or if the piston develops a leak - or if it really won't free up. RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
7th Jun 2013 7:38am |
Thanks guys, I just wanted to know if it was fixable. I don't think the piston is leaking and I'm fairly sure the rubber boot is ok. So I'll give it a go next week and post the results. Bushy
7th Jun 2013 3:33pm |
