Home > Maintenance & Mods (L322) > Plastic restorer / treatment
Knotty
Hi all,
Can anyone recommend a product to restore interior plastics eg where the load cover slides in and also exterior eg on the bonnet....ideally a cutting compound to remove scratches and restore shine.
Thanks
Post #192000 4th Jun 2013 1:06pm
Mark.abersoch
United Kingdom 2010 Range Rover Vogue SE TDV8 Bonatti Grey
Wurth do some good plastic paint for the exterior. Depending on what your doing inside I'm sure this should be fine.
http://www.wurth.co.uk/product/plasticdyeplast this is what I use on the plastics bits and its spot on! 2009 TDV8 Vogue SE - Bonatti Grey
Post #192001 4th Jun 2013 1:10pm
wedgel322
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
I use Meguiars PlastX which i use on the pillars, back of mirrors and the strip on to of rear bumper.
I would recommend it. I apply with a small sponge and then rub off with clean cloth.
http://www.meguiarsdirect.com/product_detail.do?q=4596 2003 Range Rover HSE 3.0 TD6
Java Black, Cream Leather Heated seats all round, Sat Nav, Rear TV's.
2013 Range Rover Autobiography 4.4 SDV8
Black, black and piano black. Rear entertainment system. 22 inch turbines
Post #192005 4th Jun 2013 1:23pm
pld118
Re: Plastic restorer / treatment
Try reading these too/ might be something there for you: Thumbs Up
http://www.fullfatrr.com/forum/topic18821.html?highlight=c4
http://www.fullfatrr.com/forum/topic18696.html
Post #192010 4th Jun 2013 1:40pm
Knotty
Thanks gents.
Post #192042 4th Jun 2013 6:25pm
pld118
Gtechniq C4 is very expensive.. As reported, I used this on the plastic tray between the front windscreen and the bonnet about 3 weeks ago.. It now looks rubbish again. Faded pastic and annoyingly unsightly... I used the C4 on the roof antenna and it still looks fine... Disappointing unless I've prep'd it wrong... Banging Head
Post #192428 6th Jun 2013 9:49pm
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Shocker, I was literally about to order that as seemed like the perfect stuff to sort that faded panel at bottom of windscreen!?
Did you prepare with isopropyl alcohol stuff...
Reviews seemed so positive ?? Neutral Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #192455 7th Jun 2013 12:00am
pld118
I just cleaned area with shampoo before applying.
Post #192466 7th Jun 2013 6:59am
The WURTH stuff is Dye so will last a lot longer...
£33....
http://www.amazon.co.uk/Wurth-Plastic-Plas...B002Y9BEEQ
Post #192477 7th Jun 2013 8:13am
I am going to give the Autoglym product a try and will report back as its much cheaper at £4.99...
http://www.amazon.co.uk/gp/product/B0060KJ...&psc=1
Post #192479 7th Jun 2013 8:22am
pld118
Thanks.. people on Detailing World saying I can't have prep'd it right as they're adamant Gtechniq C4 is excellent and will last up to a year..
Post #192534 7th Jun 2013 12:49pm
pld118
A detailing world user says of Gtechniq C4, to use:
'IPA = IsoPropyl Alcohol
I've bought mine on ebay, and got the very high strength stuff. Have a look at listing number eBay Item No. 130542507915 for a bit more info.
For general cleaning I dilute it 50:50 with water from a dehumidifier, but cheap deionised water from Wilkinsons or the like is fine.
It's fantastic stuff for getting all kinds of things ultra clean. And if you haven't used IPA before C4 I reckon you haven't seen how good C4 is...'
Seems like a lot of hassle for a bit of plastic! Censored
Post #192702 8th Jun 2013 1:25pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
I heard that using a heat gun or peanut butter on the greyed plastic trim will restore it to look like new. But some reports say it does not last. Anyone tried it?
&NR=1&feature=endscreen Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #192754 8th Jun 2013 6:25pm
Charmer
I use peanut oil (not butter) on my wife's old Discovery II.
Embarassed
Works a treat and has lasted at least a year! Used it on the exterior rubbers and exterior black plastic.
Just applied it with a folded up paper towel.
Post #192787 8th Jun 2013 9:00pm
supershuttle
I just rubbed silicon grease into mine , it's been black for a couple of months now. Geoff
Post #192805 8th Jun 2013 10:55pm
