Home > Orders (L405) > Locking Rear Diff
This topic is locked: you cannot edit posts or make replies.  Down to end
Locking Rear Diff
Has anyone specified this option on their car? Is there any reason you would want it other than for hard core off road driving?
I have it on my current car but not sure it has ever had much effect in the type of driving I do. I am inclined not to spec it.
Post #192218 5th Jun 2013 7:02pm
Hardcore off road, extreme snow/ice or drag racing Cool
It can only be locked on a slippery surface or when going in a dead straight line.
Post #192224 5th Jun 2013 7:25pm
johnf
2013 Range Rover Autobiography 5.0 SC V8 Bonatti Grey
I did, on the advice of my brother-in-law who used to design F1 cars. He reckoned it was a worthwhile enhancement for on road driving. Obviously I can't identify any benefit/intervention in day to day driving but I feel happier knowing it is there (and it was a tiny percentage of the overall vehicle cost).
Post #192240 5th Jun 2013 9:43pm
johnf
Plus, I should add, used on F1 cars which rarely go off road
Post #192242 5th Jun 2013 9:44pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
I have seen mine locking when towing the caravan through muddy sites.
Ian
Post #192267 6th Jun 2013 6:55am
That's covered in my drag race comment - used as part of launch control.
Post #192411 6th Jun 2013 6:50pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Why would you think that? On the road it should tighten the line under power.
Post #192413 6th Jun 2013 7:00pm
Is it variable or limited slip in a way that the standard diff isn't ?
I thought it was just a straight lock - so when engaged it locks the rear wheels at the same speed - in which case it can only be used on a slippery surface or when both wheels need to move at the same speed ie a straight line.
Post #192438 6th Jun 2013 9:26pm
Philip
It's a computer-controlled variable LSD - the locking/pre-loading is done by an electric motor.
Post #192443 6th Jun 2013 9:47pm
campaj1
surely just another thing to go wrong? terrain response is enough for most folks
Post #192461 6th Jun 2013 11:55pm
5.0
I can see the point of having a LSD in a performance car to aid traction out of corners and off the line etc. but I don't really plan to be power sliding my Range Rover or doing drag starts and my off road driving is limited to parking in fields so I think I will give this option a miss.
Thanks for the input. Smile
Post #192469 7th Jun 2013 6:33am
In the general scheme of things and the way the weather is in this country I personally would plump for it but leaf not forget the self parking is then lost... But that's due to change this year or next iirc Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #192481 7th Jun 2013 7:27am
5.0
I have not personally tested the park assist but I have heard that the space it requires to actually work in is so large that unless you are absolutely hopeless at parking you would find it very easy to park on your own anyway.
Post #192502 7th Jun 2013 9:03am
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
The active Diff also worked with the torque vectoring when cornering in the wet which gives more stability and of course more grip. Far to many gone...
Post #194813 18th Jun 2013 6:34am
This topic is locked: you cannot edit posts or make replies.  Back to top
