Home > Technical (L322) > Removing rear spring on td6?
b20wht
My rear air spring has developed a squeak and I need to remove it to investigate. I was just wondering if anyone knew of a guide of how to do it, or any tips from those that have? As my searches have drawn a blank on it. Embarassed
Post #192104 5th Jun 2013 6:23am
The squeak is most likely from the rear rose bushes
Post #192109 5th Jun 2013 7:08am
+1 Thumbs Up
Post #192120 5th Jun 2013 7:55am
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
As above it is likely the bushes that are squeeking. There is a Wiki on here for the part numbers and a how to.
Just out of intrest though, From those who have replaced the rear air spring how did you go about it? I will be doing mine in a few days, I will do a write up. But any tips greatly apreciated. There is little info about the rears, but they look straight forward enough.
Post #192149 5th Jun 2013 9:24am
RAVE gives a good account of how to do it.
Here is my howto on the rear end (there are others on here) http://www.fullfatrr.com/forum/viewtopic.p...066a64f102
plus fisha's excellent bush replacement howto http://www.fullfatrr.com/forum/post140711.html#140711
The trickier bits are deflating the bag and keeping it "rolled up" .
Post #192163 5th Jun 2013 12:29pm
