Home > Maintenance & Mods (L322) > rear drop links replacing |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
I want to replace these as it was noted at last service there was slight play in rears .As they are cheap I thought I would replace. Also going to replace fronts. Has anyone replaced rears as dont seem as easy to do as fronts. If so any tips advice etc? Thanks. Also once done what effect on handling will this have apart from less lean in corners?
2nd Jun 2013 7:55pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Rear drop links not difficult at all, but can be a bit tricky to stay on the flat with a spanner and get access with a ratchet.
2nd Jun 2013 8:04pm |
thanks Joe. Present :2008 TDV8 HSE
2nd Jun 2013 8:21pm |
on the front link noticed at the top where the rubber is its not flush it sits outward which cant be right hence my reason for doing fronts. Present :2008 TDV8 HSE
2nd Jun 2013 8:24pm |
