Intermittent engine cut out | |
Hi, I have a 2003 petrol Vogue (no modifications). Every few weeks the engine cuts out without any warning. On restarting it doesn't hold any revs and cuts out again. When I restart it again, revving hard, it idles correctly and I drive off. The are no warning lights illuminated.
I have taken it to two different land rover specialists and had the following work done; new crank sensor, new fuel pump, voltage faults in system identified and repaired, electrical thermostat fault repaired and air mass sensor fault repaired.
Is this a common fault and if so any suggestions on what I should look at next?
Thanks.
