![]() | Home > Technical (L322) > interior indicators, reversing sensors, sat all not working |
You could try Fuse 17: 50A on the rear fuseboard.
Jammer600 Member Since: 31 Mar 2013 Location: Bath Posts: 212 ![]() ![]() |
I had a problem similar, all on dash, no indicators, no high low beam lights, steering controls not working, reversing sensor not kicking in in reverse, and sat nab lost, went to main dealer through the chap I got the ffrr from, ballast resistor faulty and steering module behind dash! Bloody rr! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8689 ![]() ![]() ![]() |
odds are that it will be related to the caravan towing incident.
kevstar81 Member Since: 30 May 2013 Location: birmingham Posts: 7 ![]() |
Im going to try unplugging it and see if that works. The fuse things did not work at all |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35516 ![]() ![]() |
it wouldnt do any harm doing a battery disconnection.. ... - .- -.
Thats the other thing I thought about but didnt know if anything else would play uo.
a battery disconnection should reboot all the ecu's and sort out any anomalies.. ... - .- -.
Iv tried unpluging the battery and left it for 2 hours. Tried the trailer ecu and that didnt work either.
Looks like most the cluster lights are out eg seat belt, lights ect |
Have you put led sidelights in? |
so what happens when you put the caravan plug back in.... ... - .- -.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
unplug overnight and get on a charger. While the bat is charging overnight touch the + & - together. In the morning pull fuse 49. reconnect and wait 10mins then push the fuse back in. Try not to let it arc or crackle a good solid push. mine needed the fuse pulling a few times to get it to start thinking straight. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
I have not put led side lights but was going to soon.
