Home > Technical (L322) > Passenger side mirror stopped dipping |
dirtyharry Member Since: 23 Oct 2012 Location: Ashby Magna Posts: 242 |
For some reason, the passenger side wing mirror has stopped dipping when I select reverse. I have checked that the mirror selection switch is set to "driver" side, so I know that's not the problem. I can see it is dipping a little bit, but doesn't dip fully to enable me to see the kerb, as it used to.
26th May 2013 6:05am |
GreenBlood Member Since: 26 Feb 2013 Location: South West London, Surrey Posts: 84 |
Have you tried adjusting it down so you can see the kerb when it is in the dipped position? If you don't get stuck then you are not trying hard enough.
26th May 2013 7:02am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
Could just need the dipped position re-entered in the seat memory. |
26th May 2013 7:27am |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
I wonder if there are sensors or something inside the mirror. I set mine up when I first got the car and no matter what I select or set or store, my passenger mirror does move when I engage reverse but just moves in small amounts all over the shop. Looks like it's having a fit of some sort. Kinda twitching all over the place.
26th May 2013 7:59am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35293 |
this might help,
26th May 2013 8:20am |
Thanks for the info guys. It seems very hit and miss at the moment - it didn't work yesterday, but this morning it did. And it still dips ok if I adjust it manually, so there's no obstruction that I can see.
27th May 2013 11:51am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Battery reset will help |
27th May 2013 8:53pm |
Thanks Craig - will give it a go Cheers
28th May 2013 1:13pm |
Mark.abersoch Member Since: 23 May 2013 Location: Wirral Posts: 148 |
Did you sort the problem?
5th Jun 2013 10:06pm |
Thanks for the tip Mark, but I knew about the mirror selection button needing to be set to the right, and it always is. So that wasn't the source of the problem.
6th Jun 2013 6:16am |
It was worth a try. I didn't know about it for a while.
6th Jun 2013 7:10am |
Is the adjust switch on the right side? Moving the adjust switch over stops the dipping (thanks Stan)...... |
6th Jun 2013 7:26am |
6th Jun 2013 7:29am |
Gaz.... already covered off in my previous posts Cheers
6th Jun 2013 7:32am |
