![]() | Home > Technical (L322) > Td6 Won't Start - Immobiliser Problem? |
Could be the gear lever problem. Have you tried starting in Neutral, moving the gear lever to Drive and back to Park or Neutral then starting? You may need to grease the cable connection on the side of the gearbox, or get the cable by the lever replaced if bent? The problem can be caused by the gearbox inhibitor switch "not believing" you are in Park or Neutral. .
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
It may be the ignition switich failing - recently had this problem with not beeping but 'electronic noises' from the switch area - changed the switch [not including the barrel and keys] and it works fine.
+1 on DavidP. Several people had similar issues and most of them turned out to be the ignition switch. I bet Duckworth Dan can get you one PDQ. MY 2010 5.0 SC Galway green and sand interior!!
elbitrevnoc Member Since: 17 Mar 2010 Location: Berkshire Posts: 150 ![]() ![]() ![]() |
What a brilliant website this is! Thanks all. I really appreciate you taking the trouble to respond - and from all points of the globe too! Looks like the ignition switch may be the favourite - I've since seen a Youtube video of someone with a very similar problem and that turned out to be the ignition solenoid.
elbitrevnoc - the video that you posted is identical to the 'noise' that I had. Replaced the ignition switch [supplied by Dan] and all is good. |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 741 ![]() ![]() |
This is what it looks like ...
Omnigamer Member Since: 06 Oct 2013 Location: Skipton Posts: 9 ![]() ![]() ![]() |
I have just got the same fault. Does anyone know how to get to it? !!!!!!! All the Kit, none of the Wit !!!!!!! |
