![]() | Home > Maintenance & Mods (L322) > To facelift or not to facelift that is the question..... |
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 ![]() ![]() ![]() |
Ok so I have collected all the bits to update the front end of my 2003 vogue to 2006 look......
£1 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
i think this upgrade is one of the easiest ones that will transform the look of the pre-facelift fullfat..do it .. ... - .- -.
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2289 ![]() ![]() ![]() |
Since you have the parts allready, have it done, or do it. I like the 2005 facelift a lot more then the 2010 and it will probably sell a lot easier. . |
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 ![]() ![]() ![]() |
what colour parts do you have?
rich89 Member Since: 05 May 2013 Location: United Kingdom Posts: 295 ![]() ![]() ![]() |
How much you want for it? I've got a bonatti grey vogue and might be looking to do it. |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 ![]() ![]() ![]() |
Facelift it. The original look is classic but the 2nd phase models look classic and handsome.
I have a few sets if people are looking |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1749 ![]() ![]() ![]() |
Do it - I did mine a few weeks ago. Not too bad at all to do (if you have the nerve with an angle grinder)
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Comport, did you completely remove the tabs with a grinder, right back to flush the wing?
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
From what I understand the gap between the wing and the light is caused when the wing bracket is not fitted in the correct place, causing the bumper and thus light to be out of alignment.
On the 06 facelift you don't change the wing brackets??? |
What about if the 06 facelift has already been carried out as it has on my 02.
2010 conversion also requires the head light carrier and bumper end brackets. New PDC loom, lighting resistors etc. |
