Home > Technical (L322) > Juddering at low speeds - possible fueling problem
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
Good evening. I experienced a lack of power when driving the other day coupled with a massive decrease in fuel economy!.
Got home and at very low speed the beast judders, worse in reverse.
I have had redex through it and it was fully serviced [in UK] 2 weeks ago and driven has been driving faultlessly since.
Th equestion i have is that if it is a fuelling problem [duff injector etc etc] what are the implications of driving it with the exception of loss of performance / power and decreased fuel economy.
Reaso i as is that i have managed to get it booked into the supplying LR gararge here in Belgium on Tuesday but its 130km away!.
I have no visual indications of any faults anywhere.
Thanks in advance.....
David
Post #188513 15th May 2013 8:06pm
ebajema
You could have the dreaded rear brake caliper issue. Drive it for a few 100 meters and then feel and smell the discs front and rear. If the caliper is sticking it heats up the disc a lot !! Doing 130 kms with that, no way, not as bad as you describe. MY 2010 5.0 SC Galway green and sand interior!!
Post #188514 15th May 2013 8:10pm
DavidP
not rear caliper, or fronts - i checked them all = 1 rear replaced in Jan and all checked, cleaned etc etc.
It's just been through its control technique last week!.
Mechanic in UK suggests fuel - when at higher speeds its away, something to do with centrifugal [sp!!!!] force. More apparent in reverse as torque is higher.
PS hows's lagos holding up?
Post #188515 15th May 2013 8:18pm
