Home > Technical (L322) > Passenger rear door won't unlock. Urgent help please. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35194 |
there are 2 cables in the door, one connected to the lock mechanism on the inside and one on the outside..sounds like one has broken which means door card off and replace.. ... - .- -.
15th May 2013 6:59pm |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
Sounds more like the lock actuator than one of the cables if the button doesn't come up using the fob or lock/unlock button.
15th May 2013 7:16pm |
rich89 Member Since: 05 May 2013 Location: United Kingdom Posts: 295 |
So, door card off jobby and inspect? |
15th May 2013 7:29pm |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
Correct. The same thing happened on my old '02 recently. My repair was, for various other reasons, to buy a newer model.
15th May 2013 7:32pm |
Haha,
15th May 2013 8:04pm |
It seems the problem is intermittent. It will work one time, lock it and try again and it doesn't work!
17th May 2013 10:21pm |
robjp Member Since: 14 Jan 2013 Location: North Wales Posts: 104 |
I've got a similar fault on the driver's door on my FF. Sometimes the door will unlock, sometimes the button just 'twitches' and it fails to unlock. Always locks though. Had the doorcard off a few weeks ago, but I can't see anything obvious either. My plan was idiot-proof ...
17th May 2013 10:54pm |
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 |
^ Same here for my rear N/S door, most of the time it wont unlock... but if I lock and unlock several times in a row it will eventually work.
17th May 2013 11:04pm |
JarrahJack Member Since: 27 Apr 2012 Location: Perth Posts: 23 |
The solution is to buy a new locking mechanism. It is possible to repair by drilling rivets out of the mechanism and replacing one of the tiny motors (which would have failed), but a new mechanism is less than US$100 from memory, note that they are specific to each door and the part number has been superceded a few times. 2003 TD6 HSE, Zambezi Silver, Navy Trim. |
18th May 2013 3:53am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16257 |
Note to all... Once these symptoms start, investigte quickly and if your lock is at fault get it changed immediately...as one day it will deadlock itself and that will be a 10x harder job! You have been warned gentlemen... |
18th May 2013 9:03am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3967 |
I had a problem with the passenger door.
18th May 2013 9:30am |
Is it an easy job to change it? |
18th May 2013 10:32am |
A bit fiddly but easily DIY do-able... |
18th May 2013 11:05am |
I tried this earlier and it seems to have worked a treat. Locked/unlock loads of times and it unlocked everytime!!! |
19th May 2013 9:42pm |
