![]() | Home > Technical (L322) > Dunlop Airspring + strut defect... |
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 ![]() ![]() ![]() |
Hi Uli,
I have Delphi's which are the only ones for the SC and they are fine. Sounds like bad luck that yours failed, should not happen but apparently quality control had an off-day. MY 2010 5.0 SC Galway green and sand interior!!
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 ![]() ![]() ![]() |
I replaced mine with dunlops from the same shop and I am having clunks at the moment but thought it could be down to drop links or some such thing. Only noise when going over holes in the road, and not when turning. When I received dunlops , they seemed a solid quality item. MY2010 TDV8 Vogue Ipanema Sand
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
the noise first seems to come from the lower part of the front suspension, but when I build the struts out, there is a very big "worn out joint top" (my englisch is not perfect). The man at island4x4 said, that I have to make pictures of the DUNLOP sign, and they don´t need the old struts back, there must be a serie of reclamations..., will see, an inform you all. Best regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
So, problem solved, the correct and fair company ISLAND4x4 sended me money back for the old DUNLOP struts, and they don´t want them back, I will give them in the mood-basket..., but the company DUNLOP in GB itself is very arrogant and unpolite, after three mails no answer, and after next mail they didn´t believe me, and they said, that there was no reclamation ever... (here in germany, 5 guys have the same problem like mine after only 4 month!!!!) So conclusion: BIG WARNING FOR DUNLOP struts!!! Rgs, Uli (The Delphi are much better, drive like new without any noise) L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
Hi Uli,
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
Great! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
Is the top mount not a separate piece? Dont know, just wondering... There is nothing that can't be fixed with a hammer😜😜
@northernmonkeyjones, no it is one unit, not to open, because of the pipe from the suspension. Rgs, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
