![]() | Home > Maintenance & Mods (L322) > front wheel bearings |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 ![]() ![]() ![]() |
has anyone done the front wheel bearing change job at home or is it a garage job ??? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
looks like a garage job unless you have a press,
Tayas Member Since: 29 Apr 2013 Location: United Kingdom Posts: 74 ![]() ![]() |
Can you just replace the entire hub? On other cars I've just done that in the past as it's cheaper than getting new bearings pressed in. 2006 FFRR 4.2 Supercharged Vogue SE
This is not a "factory made" hub, like I use on my trike where you can't replace the bearing at all. This is a proper (big) bearing pressed into the hub. Replacing the whole hub is possible, just a lot (?) more expensive. MY 2010 5.0 SC Galway green and sand interior!!
Deasy Member Since: 26 Oct 2011 Location: Warwickshire Posts: 210 ![]() ![]() ![]() |
I had a front wheel bearing done yesterday at an indie
I can sell you the driveshaft pressing tool...
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 ![]() ![]() ![]() |
Do the drive shafts press straight out of the hub, or is there a knack? I recent had my hub and drive shaft out as 1 and the garage couldn't get the drive shaft out of the hub with a press and penetrating oil and 48hrs. Although I have since decided I will not use them again after seeing a gearbox change they done on my brothers van. MY2010 TDV8 Vogue Ipanema Sand
See my post above! All is explained there... |
You will probably find you now have a knackered wheel bearing now... They don't like presses and hammers! |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
I need to change my CV boot gaiters, I think I'll just remove the hub plus driveshaft complete and try replacing them without removing the driveshaft from the hub. Going to beinteresting... |
Not a nice job rich... Good luck |
Thanks, I've set aside a day to do it, should be long enough.... |
