Home > Maintenance & Mods (L322) > What preventative maintenance should I do?
Tayas
I've picked up my new (to me) 2006 4.2 SC now and I want to make sure it's got the best chance of being reliable. I've picked up a few jobs that need doing already and I've made a list of a couple of jobs that I think should be done (based on reading these forums). Can you guys comment on my list? It's on 93k miles with a FSH.
To fix:
Reverse camera - Replace with 2010 item.
Slight clunk at front on full lock when shifting between D and R - Identified as track rod. I'll sort this at the weekend.
Preventative maintenance:
Replace supercharger belt
Replace transmission cooler, filter and flush/replace fluid
Drain and replace coolant
Check SC waterpump is wired the correct way round
Anything else that I should do to it? 2006 FFRR 4.2 Supercharged Vogue SE
2007 Honda S2000
2008 Aprilia Tuono Factory
Post #188261 14th May 2013 4:49pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Change oil in front and rear diff and transfer box 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #188274 14th May 2013 5:56pm
scorpiont10
United Kingdom 2006 Range Rover Vogue SE 4.4 V8 Java Black
Maybe check the rear washer/wiper for leaks/signs of leaks by removing the plastic trim at the top of the tailgate ( you will be removing this to do the camera anyway) . If there are any water marks on the plastic, it would be a good idea to replace the nrv and carry out the seal repair detailed elsewhere on the forum Cool
Post #188287 14th May 2013 6:50pm
Put it in your garage and remove the wheels! Rolling with laughter
Post #188293 14th May 2013 7:00pm
scorpiont10
^ Laughing
Post #188299 14th May 2013 7:11pm
Tayas
Good plan, forgot about those items. 2006 FFRR 4.2 Supercharged Vogue SE
2007 Honda S2000
Post #188328 14th May 2013 8:22pm
