Home > Maintenance & Mods (L322) > quality of different brands
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
i must buy a viscous fan clutch unit for the range rover. which of the under-mentioned brands will be the better one:
- hella @ 85 pounds
- britpart @ 60 pounds
or should i go for the LR one which is 271 pounds (in south africa)
thanks
Post #188170 14th May 2013 6:52am
vnitos
bump!!! anyone??
Post #188189 14th May 2013 7:59am
ahebron
New Zealand
Ive had no problem with the Britpart Intercooler and transferbox motor I've fitted.
They look identical to the LR ones even the same lables.
Adrian VW Amarok 2014 Highline auto
Post #188193 14th May 2013 8:13am
Martin
Site Admin
You have to be VERY picky with Britpart parts, some are absolutely fine but some are awful.
I would go with the Hella item, you're still saving a fortune over the LR price.
Post #188194 14th May 2013 8:38am
Vogue
Ditto what Martin said. Some Britpart are OK others are dreadful. I'd also go Hella. I bought some Britpart running boards, they looked good but the rubber treads perished within 12 months!
Google Britpart Shi*part problems and draw your own conclusion ! That said a load of their stuff is oem and LR branded!
Post #188224 14th May 2013 11:58am
