Home > General > Hi from a possible new owner |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 |
Welcome to fullfatrr.com specman
24th May 2010 4:28am |
specman Member Since: 20 May 2010 Location: Fife Posts: 250 |
Thanks Delamo, it might be the Tonga Green with tow bar, or it might be a Zermatt silver without a tow bar and I will do my best to get a deal with a tow bar.
24th May 2010 6:28am |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
Welcome to the forum.
24th May 2010 12:38pm |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 761 |
I think Gordon Brown is doing that these days too! The older I get, the more I realise that people confuse wrinkles for wisdom |
24th May 2010 12:49pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
The Range Rover doesn't need programming for the tow electrics I would also recommend the 13 pin electrics over the twin 12N/S type. |
25th May 2010 3:10pm |
So how does it know to switch off the rear PDC when you attach something to the back of it then? The older I get, the more I realise that people confuse wrinkles for wisdom |
25th May 2010 4:50pm |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 |
I thought it sensed the current drain for the extra lights you just connected... ?? |
25th May 2010 4:53pm |
The tow electrics ECU detects the presence of a trailer, and communicates this to the Lighting Control Module (LCM) over the K-BUS. The LCM then sweet talks over the IBUS to the PDC module and gets the rear sensors switched off.
25th May 2010 8:11pm |
WOW Martin.....That's an impressive answer.
25th May 2010 10:27pm |
Thanks for the input guys.
25th May 2010 11:16pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 |
26th May 2010 7:28am |
If your van already has twin electrics then fair enough, but the 13 pin socket is a much higher quality fitting than the 12N/S items
Fair enough |
26th May 2010 8:34am |
That you quoting members Martin ........... ====================================
26th May 2010 8:45am |
I would have the 13 pin socket fitted and then change the van either by rewiring the two leads with a new 13 core cable, although not all used, or by fitting one of these:-
26th May 2010 11:42am |
