![]() | Home > Technical (L322) > Fuel pressure problems - 2003 TD6 3.0. |
So just to recap,
Ayrshore Member Since: 09 May 2013 Location: Ayrshire Posts: 4 ![]() |
Fuel pressure reading at all times is just over 1 bar - 1.05-1.1. Only time it got higher was when I added an extra electric pump before the fuel filter, then it read 3 bar.
do you get ANY pressure at all on the high side while cranking or running on easy start? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Nope. It never goes much above 1 bar. |
http://www.fullfatrr.com/gallery/albums/us...elling.pdf
I've already replaced the HP pump with a good used one.
You have to suspect the rail sensor then TBH.... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
wslr Member Since: 04 Dec 2011 Location: Wellington, Somerset Posts: 64 ![]() ![]() ![]() |
You need to know the low pressure reading.
Motoroffice Member Since: 28 Apr 2016 Location: Braga Posts: 3 ![]() ![]() ![]() |
Hi,
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 88 ![]() ![]() ![]() |
Ayrshore, you do know the TD6 has 3 fuel pumps, don't you?
mariner30 Member Since: 12 May 2016 Location: SW Scotland Posts: 17 ![]() ![]() ![]() |
Had exactly the same problem last week. Changed no2 pump - all good now. 2003 TD6 SE model with EGR removed
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
No 2 pump direction ok? 2010 3.6tdv8 180k km.
umitbat,
