Home > In Car Electronics (L322) > Black lear power amp replacement |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3194 |
your problem could be due to corrosion on the spikes in the male connector. Or a spike may have broken off, as happened on my HSE. I bought an identical replacement second hand from the bay and it worked fine. Was about £100 or so.
9th May 2013 6:42pm |
birchyman71 Member Since: 18 Feb 2013 Location: stockton on tees Posts: 147 |
Cheers the one in your gallery is different , the connections are all ok I'm pretty sure it's a problem with the amp itself as I had to solder bits of wire across breaks in the tracks on the circuit board after the earth fault caused bits to melt so se of the components are probably shot , just wondered if there was something else , been looking for a 2nd hand one but bmw made all sorts of variants in the same case , cheers anyway |
9th May 2013 7:56pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 |
. Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
9th May 2013 8:00pm |
I knew someone would see it that way ..... just not you Joe!! So disappointed ...... |
9th May 2013 9:43pm |
