Home > Technical (L322) > A couple of issues today.
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
I had my first issues with my suspension today.
I jumped in the rangey today and got a message, suspension lowered on the dash and no orange lights for the height selection. So i plugged in my favorite tool (apart from my hammer Whistle ) read the codes i had
u0122; lost communication with vehicle dynamics and
u0126; lost communication with steering sensor.
Tryed clearing the codes, but the problem and faults remained. So i did a battery disconnect, This seemed to have done the trick. Did she just go screwy or is this the start of more problems? There are no leaks, and the pump runs fine and builds pressure quickly.
But me being me decide to see what happens if you put a fuse in the empty fuse slot with the two cogs and a line going through the middle (i guess its the symbol for the transfer box) and i found that when you start the engine it tells you to select neutral and slow down as soon as you even start moving , it also disables the hi lo selector. And just remains in high. Does any one know the function of this fuse slot?
Regards, Luke
Post #187110 7th May 2013 8:19pm
Bofa Bill
Scotland 2003 Range Rover SE Td6 Epsom Green
That fuse if me memory serves me reet is for being tow'd when vehicle fails to proceed.
Do not drive with it 'inserted' Made in Scotland frae 'Girders'
Post #187152 7th May 2013 11:29pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
I get the same fault if my car is wet and in a horrible wind. Usually pulling over and chilling out for a few mins sorts it out. The worst time it happened I was forced to get a Burger King rather than drive home and feed myself. Obviously the mrs was annoyed, but the FFRR soon blocks that noise out!
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #187154 7th May 2013 11:43pm
barracuda816
Thanks for the replies guys.
She has been fine today, look like it was just one of those "quirks" Rolling Eyes
Post #187214 8th May 2013 3:29pm
