Home > Maintenance & Mods (L322) > Bonnet access mode
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
Bonnet access mode
Can't find this on wiki but how can the bonnet be changed to access/ workshop mode? 2009 Vogue TDV8 Nara Bronze
2002 Vogue V8 Zambezi Silver
1986 90 Pick up Deep Bronze Green
1978 Series III SWB Deep Bronze Green
Post #186775 6th May 2013 6:55am
mpirie
If you look at the bonnet hinges, there is a clip on each side with a bent out tab. These tabs lock the bonnet into the first opening position. If you bend the tabs out, the bonnet can rise to the near-vertical access mode.
Be careful though, there are two tabs, one each side and you need to support the weight of the bonnet, so most likely a two person job.
Mike
Post #186776 6th May 2013 7:08am
Budgie
There are photos of the fixings in this Wiki: http://www.fullfatrr.com/forum/topic16155.html Wink
Post #186786 6th May 2013 9:25am
And you need to pop out the two hydraulic struts ! .
Post #186804 6th May 2013 11:02am
Mr Tee
easily done on your own , unless you are short! Thumbs Up
Post #186819 6th May 2013 1:43pm
Brewster
England 2006 Range Rover Vogue SE TDV8 Buckingham Blue
I use a short piece of cord to tie up one of the struts for when you're lowering the bonnet back down, it saves it digging in if you're doing it on your own i.e. you can't be at both sides at once ..just a thought! ...Always time for a brew !!
2006 TDV8 Vogue SE
Post #187257 8th May 2013 6:09pm
Rich86
Thanks guys 2009 Vogue TDV8 Nara Bronze
Post #187274 8th May 2013 7:28pm
