Home > Maintenance & Mods (L322) > New engine needed
Theres a place in liverpool that might be able to give you a quote on an engine swap that advertise on ebay.
is there no chance the blocked could be refurbished at all and maybe oversize pistons fitted? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #186632 5th May 2013 9:33am
RugbyXV
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Baltic Blue
I've had a few quotes ranging from £2450 to £3500 +vat. I'll be taking one of them, probably the one with the best warranty. If I put in an LR straight swap, will I need to change the ECU and any other electronics or will my existing one do the job?
Post #186652 5th May 2013 10:45am
Deasy
I should imagine you will keep all you exiting ecus, otherwise it's a pain to get them all talking to each other
The engine only has sensors that will need plugging in.
I'm sure someone will correct my if I'm wrong though
Post #186654 5th May 2013 10:50am
