Home > Maintenance & Mods (L322) > Oil Filter O Ring
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Oil Filter O Ring
Right; possibly the most laughable question of the year but I'm becoming annoyed now. Could someone tell me what should happen with the O ring when I screw the filter housing back on. Should it still be visible or should it disappear completely as I tighten it all back up again?
I have a feeling that (yet again) I have been supplied with an O ring which is too great a diameter so it doesn't quite fit. The resultant oil leak is starting to annoy me.
Simple question which should receive a simple answer.
Big Cry
Post #186622 5th May 2013 8:30am
it should still be a little visible but no more than 1-2mm as it should be thick Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #186631 5th May 2013 9:31am
chris_read
Thanks for advice - I was being a bit thick. All sorted now Very Happy
Post #186643 5th May 2013 10:01am
verydisco
did you order the oil filter O-ring on its own, or with the filter? l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #334388 25th Jun 2015 1:49pm
chris_read
The large o ring comes with the new filter. I had just been a bit thick and not removed the old one from the cap, therefore there were two on at once, hence my problem. Mr. Green
Post #334395 25th Jun 2015 2:11pm
